I having power issues with motor and trim. The motor is trimmed down and I would like to raise it. I released the pressure by turning the reset screw counter clockwise but the motor will only move a few inches. Something holding it back. I have the 3 ram type hydraulic system on this 2 stroke 115 yamaha. What am I missing??
Problem manually raising 115 2 stroke
Originally posted by louisiana lad View PostI having power issues with motor and trim. The motor is trimmed down and I would like to raise it. I released the pressure by turning the reset screw counter clockwise but the motor will only move a few inches. Something holding it back. I have the 3 ram type hydraulic system on this 2 stroke 115 yamaha. What am I missing??
I have a 1984 115 which is a pig lifting via the screw release but I have never bothered to find out why as it was a complete battery failure nothing to do with the T/T that necessitated manual lifting. This was a once off.
I'd screw the screw to both its limits and when fully in release position push up and down to release the valve which has probably become stuck sitting in the one position over a long period of time. Others may advise further.
To RELEASE PRESSURE, turn the screw COUNTER CLOCKWISE.
Normal, running position for that screw, is turned in, CLOCKWISE..
Once its all the way up, set the motor on the MANUAL FLIP LEVER. All rams should be extended, then fill the fill hole to the top. You may have to cycle it several times...
Try turning the screw in very snuggly, then hit the up switch. If working properly, it'll go up. If low on fluid, broke, it won't.
As noted above, release the screw and manually LIFT THE ENGINE, set on the mechanical bracket and check fluids, etc..Last edited by TownsendsFJR1300; 02-11-2016, 08:17 PM.Scott
