to access that bolt.
remove powerhead and lower unit.
remove the lower cowling.
withdraw the speedo tube.
unbolt the bonding wire.
remove both upper and lower mount nuts.
remove the entire midsection.
now we can access the bolts for replacement.
to do that remove the mount covers and extract the mounts.
