I have a 1992 40MJHQ pull start tiller. I just replace all the oil injection lines and check valves. Lines looked old and brittle. I started it with a 50:1 premix disconnected the oil pump link rod and held it against the stop for full oil flow as per the service manual. I seemed to take a long time to bleed the air out of the lines. How long should it take? Should i be looking to replace the oil injection pump also? Thanks.
Oil pump priming
