2002 150 TXRA
I popped my carbs back on yesterday and I am getting a random (what I believe to be) sneeze about one every 3-5 mins while running on the hose. Motor, to me, appears to shake more than I think it should at idle. Everything there tells me idle is lean but read on. And, I may be biased here because I am comparing it to my brother inlaws same vintage SWS2 150 that idles as smooth as can be.
So, here's the conditions:
Carbs are spotless. They were perfectly clean when I pulled them from the previous rebuild last year. I even cleaned the espresso machine at the same time and steam cleaned all passages w/ 1400watts of high pressure steam (shhh don't tell the wife). Special attention paid to the idle circuit, all jets I can see light through are clean when inspecting w a jewelers loop.
Fully link/sync per manual..then checked and rechecked. Pilot screws are perfect/not deformed in anyway, backed off from lightly seated exactly 1 1/4 turns.
For fuel delivery tank professional cleaned last year and all new fuel lines up to the carbs w double ties or clamps at every joint. Pumps are new. Only ethanol free gas since w/ ring free and stability red. Gas in tank looks perfect. Set boat w one corner down overnight and siphoned out lowest point in the am...no water or trash. Emptied separator no water or trash. Pumped gas through the system just prior to hooking up the carbs to purge and junk that might still be in there...found nothing.
Tried idling w gas cap off to check the vent no difference.
So what to test next?
I have (2) videos of what I am calling the offending sneeze if someone knows how to post a .mov.
