Small amount of oil leaking from the side of lower unit.I have my water pump kit and lower unit oil ready to install, i will do a pressure test at that time. How much pressure should i use? I will be following instructions from a SELOC manual also any comments on using a SELOC manual?
f115 leaks oil from side of lower unit
If the TOP vent plug is NOT tightened to full torque, it will seep.
Just replaced mine as it was starting to seep. The 6' lbs was quite a bit more torque (with a torque wrench) than I was doing with a screw driver alone...Nice and dry now with new gaskets.
Obviously, make sure you have the OEM gaskets installed...Last edited by TownsendsFJR1300; 02-01-2016, 09:27 AM.Scott
115 leaking oil at air vent
The leak comes from the single side hole beside the water intake,some refer to this as an air vent but I am not sure what it's called.looking at the scematic it looks like it might have some function with the shift cam housed inside the lower unit.Going out today changing and checking crank case oil. Starting her up, then draining lower unit oil checking that.
its called a water pump drain hole.
if gear lube is leaking out of it the driveshaft seals have most likely failed.
Lower unit oil/lube can be detected by the smell of it.
It smells completely different than crankcase oil.
Put a little on your finger and then smell it
I prefer to taste it.
but
I also drink Busch Ice and Evan Williams.
not at the same time mind you.
You'll be able to run the engine W/O water to the pump!
Self lubing!!Scott
Originally posted by TownsendsFJR1300 View PostYou'll be able to run the engine W/O water to the pump!
Self lubing!!
Originally posted by 99yam40 View PostIt might overheat without water to the block and head though
Guess I pi$$ed off 1styamaha, a PM from him;
"go iron your pants .car dealers suck,boat dealers are like yourself unexscusable."
No joking around guys, this is serious!!!!!
.Last edited by TownsendsFJR1300; 02-01-2016, 08:30 AM.Scott
Un-subscribed as to not cause any issues...Scott
ÂÂÂÂÂÂÂ
