Tilt/Trim Cap Removed - What's Next?
  • Tilt/Trim Cap Removed - What's Next?
    I removed the cylinder cap from the tilt/trim assembly with a pin wrench. What's next? Should the trim cylinder assembly come out or is there more disassembly required? It seems to be stuck and I do not want to force it. This is the tilt/trim unit off of a Yamaha 2006 F90TXR.
    Here's the parts fiche for your unit:
    2006 and Later F90TXR Yamaha Outboard POWER TRIM TILT ASSY 1 Diagram and Parts
    Someone else will have to chime in re your question, (IDK)...
      put fluid in the pump and turn the pump to use hydraulics and push it out.
      watch out for the 6 balls. don't lose them.
      you will then need two more special tools to disassemble the tilt ram.
