Toggle switch, what does it do?
    Originally posted by keithparker04 View Post
    The switch you are referring to, on my 90TLRR anyway, energizes the starting enrichment solenoid (Like a choke). If you look on the right side of #2 carburetor, you should see a little red switch with three positions, normal, emergency, and off. Connected to that guy is a solenoid that should resemble this [ATTACH]2229[/ATTACH]. When you push your switch, the solenoid energizes, and adjusts the enrichment for starting, just like a choke.
    What specific model motor have yee?
    I think you have an electro-mechanical choke confused with a Primestart device. But not to worry. You are not the first. In a number of Yamaha's the toggle switch, or the press-to-choke- function on some Yamaha key switches, does absolutely nothing.
    Some think their motor starts better using the switches. If you are one of these, keep using it.
      Yep if you do not hear the click when hitting the switch it is not doing anything
