1) The unit tilts up just fine but not down. While holding the DOWN switch, it will go down easily if I push on it. If the UP-DOWN switch is not pushed then it is locked firmly in place (like it should be).
2) When it does work going down, there seems to be a "pop" as it transitions from high speed to slow speed. Almost as if it were binding for a split second.
Any idea as to what's going on here and how to repair? Thanks in advance.
