Multi-function tach problem
  • Multi-function tach problem
    My multi-function tach (part # 6y8-8350t) stopped working yesterday. It is powered up when I start the engine but I only get one dash line and no information on tach, temp, or hours. I checked the wire from the engine to the dashboard and everything looks fine on that front. I also checked the online fuse going to the start switch and it is fine. Is there another fuse that I should check? Or what else should I verify?
