What's this knocking noise when I trim up and down?
  • What's this knocking noise when I trim up and down?
    Hi guys,
    I have a Yamaha 85HP and it's making this knocking noise when I trim up and down (Link attached)
    Wondering if anyone knows what it could be?
    TIA.
    View, organize, and share photos and videos with iCloud Photos on the web. Changes will sync across your devices with iCloud.
    Hi Branchy. I generally don't click links in posts from someone that is relatively new - generally I think it's just a bad idea.
    Where is the knocking noise coming from? Can you describe the noise and better? Does the engine vibrate? Does it make a sound if you raise/lower the drive manually?
      there are handful of plastic bushings in tilt/trim mechanism. some of them may be worn.
        Sounds like the tilt tube / sections are dry of grease and binding up.
