I have a pair of F50's on my commercial fishing boat. The port engine (2021, approx 2000 hours) has started losing revs when operating at 4000-4500 (normal cruising revs for me). The engine won't stall, it drops revs to 1000-2000 and then jumps back up again. If I don't alter the throttle it would continue in this yo-yo fashion, but if I bring the throttle down it will happily run at 2500 rpm, any higher and the issue will happen again
If I pump the fuel bulb, this solves the problem for maybe 20-30 seconds. Also, it doesn't happen for the first minute or two of running at 400-4500.
I drained the VST tank yesterday and sprayed some carb cleaner up the drain tube, but this hasn't helped.
Before I take the VST tank off is there anything else I should be checking first? I wondered about air leaks in the fuel line connectors, or maybe the fuel lift pump is failing?
Thanks in advance.
Thanks in advance.
