I have twin 2005 F225s. Port engine has a high idle.....900 or so. This past off season I did T-stats. I have YDS a which shows code 29 (MAP sensor out of spec) and this is what I have done so far:
Port engine key on/engine off:
Intake press 35
atm press 30
Start the engine and there is no change in the intake press.....remains at 35
obviously it should never read 35 as that is higher the the atm pressure
I swapped the MAP sensors....no change
swapped the ISC valves......no change
swapped ECUs.....no change
Voltage to MAP sensor is 4.98V
Any ideas? Plan to make sure I didn't pinch a vacuum hose when I did stats but don't see how that would cause an elevated intake pressure.
Not that this should effect it but both midsections were done in 2021.
Engine runs perfect in gear and spins up to 6000 RPM. In gear the RPMs drop to the normal 600.
Thanks in advance.
Intake press 35
atm press 30
Thanks in advance.
