I have removed the under floor tank replacing it with a plastic tank. with disconnecting the fuel gauge can not get power. Only found 3 fuse (1) main switch/trim switch. (2) Rec/reg ecm fuel injector vsv, (3) starter relay. can some one advise if any more as I can't find them also had power before removing tank also i have had the gauges out.
Stessl
Stessl
