I have a 1987 115hp Yamaha that I just started after sitting since November. While the tilt/trim system is working both up and down it has a terrible squeal that was never present before.
In fact, when I operate the tilt button on the engine and feel the tilt ram I can almost feel the vibration on the ram itself as it goes up and down.
I just searched on this site for some info and it looks like there may be air in the system. I have cycled the tilt trim up and down at least 15x but no change.
Before I do anything I was hoping someone could confirm if this sounds like air or low fluid as the problem. How high should the fluid be filled?
Also, what fluid should be used if I have to top off the tilt/trim reservoir? Can I use a generic from West Marine?
Thank you all.
Thank you all.
