2000 OX 66
2 stroke
250 hp
sx250txry
dropped drive too change upper & lower seals ,
shifter seal
impeller
gear oil
when removed throttle was in N - prior too dropping drive no grinding when shifting
did not move shifter while changing seal plus not easy too move
installed - fired up and now I have a slight grind in F , louder in R
dropped drive 1/2 dz times , drive supported by tie down straps so I can drop just enough too get fingers , tool , and view whats going on ,
I must be off a spline , twisted drive , no change
working myself
have help coming over so I will have another set of hands
should one person move throttle slightly or something else
thank you
2 stroke
250 hp
sx250txry
shifter seal
impeller
gear oil
working myself
thank you
