F130A/2019 neutral throttle speed goes under 700 - how to increase?
  • F130A/2019 neutral throttle speed goes under 700 - how to increase?
    Hi folks,
    happily we use the F130A from 2019 - great engine.
    Now we have the problem that the engine goes off in neutral throttle speed almost everytime and after few seconds (motor is on normal tmeperature and running normal else), and i feel it is because it is too low, it goes down to 600.
    Normal function is super, it runs well.
    The problem is new. Might be because recently the water cooling behind the rectifier was blocked (mud in the outlet hose) and then the rectifier overheated and the sytem shut of itself. We cleaned the colling system and all runs well.
    Could as well be the spark plugs, but they look normal - anyway, working hours unknown sinece we bought the engine end of last year.
    Where can i adjust the neutral throttle speed by myself or is that a function of the computer steering? I am engineer but did not find anything regards that.
    Thanks a lot,
    Tobias
    https://skadarlake.me
    Skadar Lake Boat Tours
    sorry - duplicate dues to internet problems.
    Go here https://www.yamahaoutboardparts.com/...throttle-speed
