As noted in the title, I have a 1996 60hp 2 stroke. Can I connect a temperature gauge to the temp sensor that activates the warning buzzer? I would like to be able to see if the temp is rising before I get the warning.
I assume I will need some kind of bushing or adapter to convert the treads from those of the plug (Straight Screw #23 in diagram) to the threads on the sensor (NPT3/8). The boats.net part number listed ends in M1400-00. Is that indicative an official thread I can use to search for a bushing?
