I have a 2015 F250XA. I had an overheat alarm at idle. After I dropped the lower unit I decided to check the dry exhaust by hooking a hose to the inlet tube. I have water coming from around the section circled in the picture below. There is no water coming from anywhere above this joint. It seems like the seal between these 2 pieces has failed. How critical is this for outboard cooling performance?
Note: I used a picture from the internet. This is not my engine. Mine does not have the white pitting.
