I've got a 2021 four stroke 115 with about 500 hours. It will run fine for 3 to 5 minutes and then cut the power to the fuel pump. If you let it sit for a bit, it will come back on but then cut it again in less than a minute. Almost like an overheating thing. I finally wired it direct and has been running ok but i would like to solve the problem. Here are the fault codes but don't see any that would seem to fix the issue:
18 (throttle position)
58 (High pressure fuel pump power)
28 (shift position switch)
any help appreciated
Matt
Matt
