Starter motor doesn´t kick in
  • Starter motor doesn´t kick in
    Helllo,
    When trying to start I only get a buzz sound from the engine. The starter motor doesn´t kick in. I have power in the battery. I even borrowed a battery booster, but the starter motor didn´t react any differently. I have tried to short circuit the starter relay without any different result. After waiting a few hours I tried again with the same result, but on the third attempt the motor started and ran nicely!
    Now I don´t know how to repair an engine that works !
    It is a Yamaha 60 hp Autolube from 1989: 6H2 S 100508
    Thanks for your advice !
    IMG_20240801_123214r.jpgUpdate
    The following day the starter is faulty again. There is only this buzzing consisting of a clicking sounds in quick series.
    Today time I had brought jumper cabels and I connected directly from the battery to the red connection on the starter motor. This got the start starter motor going and the engine started ! :-)
    I tried short circuitng over the relay again, this still only gives buzzing sounds.
      my guess is a bad connection on either the positive or negative cables,
      or a bad cable itself
        I have found the problem. When I put the jump cable from the battery on the input to the relay then everything work normally.
        So I have have a bad power cable that needs to be replaced. :-)
        What cable cross section do I need? The cable will be 2.5m long.
          I would check the connections of that cable before saying the cable itself is bad.
          but you can always look at what you have to see what gauge it is
