I'm as confused as you. I'm honestly baffled, because I know these motors fairly well as I have another set on another boat. I know the electrical systems are top notch and rarely fail.
Yamaha 6Y5 Tachs going Haywire
Originally posted by eelpoint View PostI've done similar with Eric from GaugeSaver. We started with one connection (yellow) to one tach, then tested by turning key switch to corresponding motor on. If we were successful we then went to green then test, black then test, blue then test, We then connected the Fuel Management and Speed gauge (similar procedure) Yellow then test , Black then test, Blue then test, Red then test, Green then test, Green/white then test. We then moved onto the Port Tach and connected that separate from Starboard Tach, Fuel Management and Speed Gauge... all tested good. Then we moved to the 4-pin connectors and as soon as we connected the Orange, Black, Grey 4 pin connector (not the Pink wire according to the label) gauges went into cardiac arrest. I can try this test in the reverse method as you suggest, would expect same results No?
One motor only please.
