1993 225 trxx. Put it "away" about 5 years ago. Thought it was going back in use in a short period of time- now 5 years later I'm ready to use it.
Here's the problem- I did nothing to preserve motor at that time.
I've cleaned rebuilt carbs, fuel pumps and new plugs. Checking all adjustments ,etc now. Engine is on stand in shop so easy to access everything at this moment.
Should I be pulling the oil tank(s) apart and cleaning them> Should I change fuel lines, oil lines. etc?
Surprisingly the carbs were very clean for being "abandoned" Everything still looks good throughout the motor (wiring, lines, etc)-but we all know how that can go.
So this leads me to ask for advice and suggestions on whether I should start replacing parts, or get the thing fired up to see if I have any problems. Also, should I spray some wd-40, etc in cylinders before I try to turn motor over (even by hand)?
Thanks for everyone's input and advice
