Hope this is not a duplicate. I was almost done with the post and fat fingered the keyboard and it disappeared....
Engine starts up and goes through idle sequence. When it idles down it runs approximately 1100 RPM with muffs on driveway, approx 900 RPM in river. Idling along for a minute or so and it suddenly stumbles like it misfires. Usually it will recover and continue to run but occasionally it will stall and die.
Following troubleshooting analysis in my service manual, I have gone through the entire fuel system. Flushed the fuel tank, changed fuel/water separator, changed fuel filter on engine, cleaned carbs, even ran engine off of a portable tank thinking perhaps the fuel supply line was collapsing. When engine dies I have drained the carb bowls to make sure there is fuel in them. I am reasonably certain I have eliminated the fuel system as the problem.
Next the manual points to the electrical system. I have changed plugs. Ran the engine until it died. Pulled the plugs and Nr 1 was fouled black, 2 and 3 were still clean as a whistle. Possibly spark plug cap or wire? The ignition coil and wire is a little pricey to just be easter egging to possibly hit on the problem.
Any constructive comments would be greatly appreciated. Thanks in advance.
