I was reading owners manual for my 89 200hp and it says to disconnect the quick connector for the fuel line after each use. I have never done that which probably explains why I have to crank for long time to start. Fuel draining back. What do others do?
I would think disconnecting after every use would wear the o-ring on the quick disconnect out over time.....
No real harm in a bit of extra cranking to start is the way I look at it....
