1992 ProV 200 fuel check valve
  • 1992 ProV 200 fuel check valve
    This motor has a fuel line check valve that I have heard causes issues. I have tried to start it (got it last fall). Should I just remove it? My older motors don't have it and all I can see that it might be good for is not allowing fuel to drain down to make it start quicker next time. Other than that it could fail and cause restriction to flow.......
    where is this check valve located?
    if it is not on the motor then it is not part of the motor
      Are you talking about an anti-siphon valve at the tank?
      Are you having issues? It's not clear from what you wrote.
      If you're having issues starting the engine - don't start replacing things just because you read about them online. There are many reasons why an engine may not start - investigate - don't just replace willy-nilly.
        Between fuel filter and pump. 6R5-24408-00-00
        Only used on ProV motors in 1992.....why are they any different?
          So this is kinda funny... I googled that part number and a thread, from this site, came up first! From 2012 and guess who started the thread...
          https://www.yamahaoutboardparts.com/...-feed-assembly
          From THAT thread, it looks like it's not necessary. You could just remove it for a while and use a barb to barb connector - see how that goes.
            Not used on ProV150 but is on 200 and 250.
            Yeah...10+ years and I'm still wondering......
              I'm only guessing that it has something to do with the type of carbs - but that really is just a guess. I guess (again) you could remove it and see how things go - could always put it back.
                Carbs are same type. I think I'll ditch it. Draining back better than restricting if it's no good. Maybe they were just trying different things....
                  I was wondering that, too.
                  I can't I ever recall seeing this on other brands/years, either.
                    remove it,
                    and see if you have to pump the primer bulb before starting every time, or just sometimes.
                      Yeah I bet no need to pump primer with that. A friend had a 150 OMC that he said never needed to prime....maybe it had a check valve. My other Yamahas always need lots of priming after sitting more than a day.....
                      You would think the primer bulb would prevent back flow since basically a one way device.
                        I don't know if it's a "perfect" seal, but yes, it should... as long as it's oriented in the right direction and facing mostly uphill.
                          I think I'll ditch it....one less thing to worry about if fuel issue arises.....
