At an ambient air temperature of 45-50 degrees I can see the motor taking quite a while to warm up. Possible 10 minutes even.
Now keep in mind that the carburetors have different circuits in them. It is possible that the idle/low speed circuit is fouled in which case it won't idle or run well at low speed while running like a raped ape at high speeds.
Many many Yams will benefit by going up an idle mixture jet size or two, or three.
