I don't think I am getting fuel to the cylinders. I am getting fuel to the high pressure pump. I have a 2001 225 vmaxx 2 stoke. It was running fine til I did some rigging on the motor. I believe all wires are connected. How can I tell if the high pressure pump is working. If it isn't any idea would be appreciated.
Help with Vmaxx 225
Help with vmaxx 225
Thanks for the help. I turned the key to on and the high pressure pump did not turn on. This is where I thought my problem was from the beginning, just didn't know for sure. I bought the boat and replaced the floor. Then hooked the motor up and it started and ran fine. I then unhooked the motor to run the wires through a two inch rigging and re-hooked the motor. This is where the self inflicted problems started. The motor has been rebuilt by a boat shop that also disconnected the oil pump. So I believe I have a broken wire or something is not hooked up. I have checked and can't see what I missed. There are wires that are disconnected when the oil pump was eliminated. I bypassed the shift switch just to make sure that wasn't the problem. I would appreciate any idea before I have to take it to the shop. Thanks
