help please yamaha 200 2t salt water II
  • help please yamaha 200 2t salt water II
    Hello and greetings to all
    * I need help with my engine I'm writing from Venezuela is a salt water yamaha 200 series II 1997 and need a crankshaft as mine was damaged
    I have a problem with the number of parts of the crankshaft as there are many models and I want to go wrong when buying
    the engine serial is 6G6-UL-503421
    I am very confused with part numbers ... here annex some pictures of the engine crankshaft and if I can really help thank you very much thank you
    [IMG]blob:https%3A//mail.google.com/6da15504-da29-47ac-8bd9-5137b68c3453[/IMG]
    [IMG]blob:https%3A//mail.google.com/694b0f32-441c-4537-8c11-ba6cd6c2d065[/IMG][IMG]blob:https%3A//mail.google.com/ce93a1bc-f042-4745-83bb-bfcf69bb3912[/IMG][IMG]blob:https%3A//mail.google.com/5987641f-c73c-4063-bf0d-da03ae69a908[/IMG][IMG]blob:https%3A//mail.google.com/2db83483-4005-41c3-85be-28dec1016b32[/IMG]
    Is the model of your motor a 200FETO? If so, it should be the equivalent of a USA model S200TXRV. Here is the parts catalog that depicts the crank shaft for those models.
    1997 S200TXRV Yamaha Outboard CRANKSHAFT PISTON Diagram and Parts
      and I think I have a good parts doner motor , motor ran well, kept snapping off the tang at the top where the starter mounts.
      heads,crank rods and such were fine.
      my wife was born in caracas and lived there until 08.
        Sir Rodbolt
        Was that due to water intrusion or a funky mount design..I usa a Lot OF ARCO brand starters ( usa Made) and never have had a issue,,their tech department will tell you that's due to water intrusion (duh) but I would your take on it ?? VEN. pretty girls and Great Fishing !!
          no water, I think the first break was due to loose mounting bolts.
          after the 3rd time it was welded back on the customer bought a long block assy.
          only thing that was wrong when I replaced it was the broken starter tab.
            hello thank all they were very helpful part number is 6G5-11411-00-00 will buy and bring a look. I think it was by water deterioration had 17years Original engine running and it was time to refurbish
            good thanks to the situation of Venezuela have to buy the crankshaft used by ebay. It seems like a good idea? alguein not know having a crankshaft in good condition
              Send a PM to rodbolt and find out how much he wants for his crank shaft.
                not gonna sell the crankshaft, will sell the entire block assy.
                low hours just cannot mount a starter to the block.
                the block is a goner.
                the internals should be ok.
