buying a used boat/engine for family
  • buying a used boat/engine for family
    Hello,
    I am hoping I can get some opinions and advise: I am looking at buying my first boat from a dealership - 2013 Hurricane 188 Sundeck with a 150hp Yamaha outboard engine. This engine has 1500 hours on it - I have asked to see at what RPM's these hours have been ran under and I am told 3,000 to 4,000 for the vast majority of those hours - My use for this boat will be as follows: family of 4 on a 32 mile around lake in which I will be using the boat/engine for mostly cruising but some tubing and fishing. Should I be worried about the # of hours. Thank you in advance for any advise and wisdom.
    what year/model is the 150?
    Fresh water or Salt water?
    any service records on the engine?
    Visible condition?
    Compression Test #'s
      Originally posted by Lakelure View Post
      Hello,
      I would be very cautious 1500 hrs at 3000 to 4000 rpm is a lot of hammering.
        if well maintained, it aint broke in yet.
        have a leakdown test done.
        DO NOT do a compression test.
        have the gearcase pressure tested.
        take it out for a seatrial.
        at the seatrial load it and make sure it will turn 5800+ RPM.
