Hi all,
I had the NMEA2000 system successfully communicating between my 2021 T60 Yamaha and my 8312 Garmin sounder (RPM, Fuel usage etc). It's a simple setup, NMEA Starter Kit & Yamaha Engine Interface Cable for NMEA2000. Only 3 backbone T- pieces in use, 1 x 12v in, 1 x to sounder & 1 x input from outboard.
Last outing I noticed I no longer had communication to the sounder, I've had a Garmin tech check out all the cabling, swapped out all the NMEA cables and Tee's except for the Yamaha interface cable, checked the 12v input fuse, and checked the resistance on the interface cable but still no joy.
Has anyone had a similar issue they've managed to fix or is there some way of checking if the BUS connector on the outboard is actually sending the signals it's supposed to be?
Any assistance or suggested greatly appreciated.
