I'm setting the oil pump link adjustment on my 2004 90tlrc 2 stroke. this part and the carb linkage at the oil pump were not getting along very well. because this part has a obvious separation the threaded end on the carb linkage has lots of slack when inserted in the part as you might imagine. I cannot even tighten the nut on the linkage. is the part broken or what?...Thanks
