Hello,
I have a 2014 F9.9XPB with remote controls that is very hard to start in the cold. It has been back to the dealer a couple time but they only messed with the file line pump bulb. Not too confident in that dealer. The electric choke does engage when key is pushed in. After many minutes of cranking finally giving it full throttle and backing off while cranking it started but would not hold a low idle until it warmed up. In warm weather it is harder to start than I like too but not so bad. I have not spent much time with it or tried manually choking to see results. I am looking of others who may have the same experience and found a solution. I am sure it is in the fuel feed / choke.
