Does my 2004 2 stroke 90hp Yamaha have a pre-test buzzer test or warning test before start-up. Mine does not do this but is it supposed to?
2004 90hp prestart warning buzzer test
Single engine Yams do not normally sound the buzzer prior to start up. To make sure your buzzer is working activate the kill switch and then crank the motor. It won't start but the buzzer should sound. Turn the key to the Off position to stop the buzzer.
Originally posted by fastback4 View Postwell I just winterized my engine so i'll look for the disconnect to the starter. If I turn the key to start my engine will crank but not start with the emergency stop activated. will that do?
the 90 two stroke will never sound a buzzer with the kill lanyard disconnected.
the EFI 4 stroke 90 will.
to test the 90 two stroke simply disconnect the pink temp switch lead,ground it,turn the key on.
no single engine Yamaha does a self test, at least not for the US market.
Originally posted by 99yam40 View PostSorry for the miss leading on that info I thought I knew,
but Rod straightened us out on that finallyScott
if your ever in doubt look at the CDI or ECU connection.
if there is no brown wire(start relay signal) it doesn't know its cranking and cannot set an alarm for a start and stop signal at the same time.
fairly simple actually.
ÂÂÂÂÂ
