Hey my trimmotor tilt area works normally.
the trim mode up is normally , but down came suddenly very slow and wails quietly , takes 30-50 second to down.
When i pump up and down in trim area 2-5 times it suddenly takes normal .
Half day later same slow cames back.
I take trimmotor leads from solenoid and switch them to battery> slow and quietly down, up goes normally
The bad is only in trim area down and it comes suddenly 2 weeks ago.
What is on?
No bad brushes or bent rams , because it suddenly wors normal and tilt (and trim up)works fine all the time.
I Wonder it is a valve in the pump that is jamming, but which valve?
What is on?
