Thanks for the clarification.
Changing primary fuel filter
townsend and w/s
21M is for carbs.....10 is for Fuel injection...Townsend,, outboard fuel line is not black....grey or white and you might want to look in to Otiker clamps.. your primer bulb looks like a merc with the yellow bands with the redesigned shutter valves.... plastic bottoms W/S are for under deck app's...aka,, not to be in the elements like UV's..btw,, I showed your bike to one of my clients that has a bike shop and he started foaming at the mouth !! LOL.......and never,never use telflon tape,,nope,nope....GGRrr !!....PPS,, and I see a water speed sensor hanging out of your motor loom !! Yes, Im picky,,folks lives depend on my work and wisdom..it is what it is,, what it is.................
Originally posted by TownsendsFJR1300 View Post2 Microns????
I posted in another thread about 10 micron filters, which allow smaller particles to GET TO THE INJECTORS.
Who makes 2 micron filters and more importantly, ARE there ANY ISSUES /downsides with fuel flow (CFM) with the better filters?
The concern is that it should clog faster than a 10 micron filter since it is not allowing contaminates between 2 and 10 microns to flow through the filter media. But this should only be the situation if one is getting a continuous supply of dirty fuel. In my case I installed a vacuum gauge to the other outlet of the filter head to monitor any restriction to fuel flow. I ran mine for several years with many hundreds of gallons of gasoline flowing through and it never got to the point of needing to be changed because of a fuel flow restriction. Change a fuel filter on a simple yearly basis and without a vacuum gauge being in the loop many perfectly good filters are getting thrown away.
Like the use of hydorfoils, anti-siphon valves, filters with plastic bowls below deck and some other stuff, the use of a two micron filter seems to be somewhat controversial.
I report, you decide.
Originally posted by bajakeith View Post21M is for carbs.....10 is for Fuel injection...Townsend,, outboard fuel line is not black....grey or white and you might want to look in to Otiker clamps.. your primer bulb looks like a merc with the yellow bands with the redesigned shutter valves.... plastic bottoms W/S are for under deck app's...aka,, not to be in the elements like UV's..btw,, I showed your bike to one of my clients that has a bike shop and he started foaming at the mouth !! LOL.......and never,never use telflon tape,,nope,nope....GGRrr !!....PPS,, and I see a water speed sensor hanging out of your motor loom !! Yes, Im picky,,folks lives depend on my work and wisdom..it is what it is,, what it is.................
ÂÂÂÂÂÂÂÂÂÂÂÂÂ
