OIL LEAK
  • OIL LEAK
    I HAVE A 2004 90 HORSE TLRB WITH AN OIL LEAK. WHEN MY MOTOR IS STORED IN THE TILTED POSITION I HAVE NOTICED SOME OIL ACCUMULATING IN THE SPLASH WELL OF MY SKEETER BOAT. I REMOVED THE MOTOR COVER AND NOTICED OIL GATHERING AROUND THE FRONT MOTOR COVER LATCH. AT FIRST I THOUGHT IT WAS MABY A SPILL FROM FILLING THE OIL INJECTION RESERVOIR SO I USED RAGS TO SOAK UP ALL EXCESS OIL. 1 WEEK LATER THE SAME THING. FULL OF OIL AGAIN. I CAN NOT FIND ANY VISIBLE LEAK AROUND THE RESERVOIR. ANY SUGGESTIONS ON WHERE ELSE TO LOOK?
    My 225 was leaking from the cap on the oil resevior in the engine. Same accumulation areas that you have. I put a SS hose clamp around the rubber cap and no more leaks.
    Good luck.
    Mako 211 w/225 Saltwater Series
