Last Wed I was heading down the intercoastal canal running about 5K RPM and things went south.
loud noises and then just some tapping.
Dropped RPM to 2K & turned around headed back to bout ramp.
once across the cut to the gulf it got loud again so I shut it down and push poled back to the ramp along the edge of the canal.
Pieces of ring and piston missing on exhaust port side of cylinder #2.
head beat up and piston has pieces inbedded in it.
cylinder is scored up in the area
Due to the welding and Epoxy putty I have used in the past to keep this motor going I am not planning on boring or resleeving.
Not finding rebuilt 40s or used good blocks ,I am thinking about putting a new F40 on my 16ft Express.
waiting on a reply from the local Yamaha dealer on cost, but found on this web site the F40 would be around $6K.
If I bought on the web, how would the warranty work if I installed it myself?
Do I have to have a local dealer do the install?
will the old 703 controls work with the new F40, or will that all need to be replaced also?
Not sure if the old control wiring would plug into the new F40 or the throttle and shift cables work properly.
fairly sure the steering Should work.
But not positive about that either.
Any info on this would be appreciated
