Hullo, I took apart my Yamaha F60T steering tube (STEERING BRACKET ASSY 69W-42510-01-8D). I will be changing out the bushings and O rings, but the bottom of the tube is corroded to the point where a new circlip will not have enough material to fit. Otherwise, the steering tube is functionally sound - the lower splines are all intact and everything else looks ok!
I noticed that in taking the tube out, the steering tube splines tend to seize within the lower steering yoke. It was quite a pain to remove!
I have been advised by the marina mechanic that I will not need to fit the circlip and that I would be ok to reuse the steering tube as is.
Would this be correct?
Cost aside, there's a 4-6 week wait for a new steering tube and I would also be loathe to discard an otherwise functional part!
Thanks so much!
Thanks so much!
