Hi, I noticed a bit of fore-aft play on the engine and have been advised that the upper dampers on my 2011 Yamaha F60T need to be replaced.
Tried to get the local agents to do the work, but they have informed that they are too busy to even schedule the job! They've also advised that:-
1. The lower dampers will need to be removed to change the upper dampers, and so I should go ahead and change those as well; and
2. The oil pan will need to be drained since the mid section will need to be removed.
Could I please confirm that both of these statements are correct?
I have over 1600 hrs on my engine and to date, have done all the necessary maintenance and repairs myself. The engine has so far been faultless. But this would be the biggest job I've attempted so far. The head mechanic from the local dealer has been helpful. Between a few calls with him and going over the service manual/parts diagrams, I think the sequence would be as follows:-
a. remove lower unit
b. drain oil pan (not sure if this is necessary?)
c. remove power head
d. remove lower mount covers
e. remove oil pan (not sure if this is necessary?)
f. replace upper and lower dampers and bolts
g. replace powerhead gasket
h. reassemble.
Have I left anything out? The service manual does provide an easy to follow step by step on removing the powerhead.
Is there anything I should be particularly careful with? The mechanic has said that the lower damper bolts will almost always be seized so I should be prepared to have to cut and knock them out. Also, I'm guessing I need to ensure I don't get gunk in the oil pan while cleaning/prepping the surfaces for the new powerhead gasket.
Thanks in advance!
h. reassemble.
Thanks in advance!
