I’m running hot, plugs show both lean condition and overheating condition if that makes sense, . I don’t know what’s causing it, I Rebuilt carb, new water pump, thermostat, new plugs, new oil,
I should note I didn’t touch the air/fuel mixture screw because there is what I believe a plug in front of it and I can’t remove. I’m guessing I should drill out? Try to pull and clean?
few questions can a bad oil pump cause overheating and result in showing a lean condition on spark plugs cause of high temps?
I thought maybe a water issue but pulled the heads and water system is clear. No obstruction.
Any help on where to start to diagnose I would appreciate .
