Hello sorry for all the post. But I just replaced he powerhead and put new gaskets but I had to dissemble the oil pan to clean out the metal chucks. Below is the problem I’m having.
With the engine off, running water On the flush port, after about a min or so once water builds up in the midsection then starts to trickle out of the oil drain plug boot.I replaced all the gaskets. Water is coming out of the prop. I see the water coming out of a lower hole in the front of the motor midsection then it build up and comes out of the oil drain plug boot.
