2012 F115LA TPS Setting need help
  • 2012 F115LA TPS Setting need help
    hi all,need help...could not set tps to specs..0.732v...is there different setting for this engine?Currentlly at 1.1v at key on...i can only bring it down to 0.8v max,not able to do static test with ydis due to engine in gear or running error.It has a single unit throttle body.
    From where are you getting the specification of 0.732 volts?
      hi boscoe99,,i refer to the 2006 model service manual...does it apply to this singe unit throttle body?
        I see no F115LA in 2006, so I would think you need a manual for your 2012 F115LA
          The F115TLR and the F115LA are completely different models.
          As 99yam indicates, you need the correct service manual.
            i don have the 2012 F115LA service manual,so i'm hoping if u guys have one and willing to share the tps settings value.
              i have the f115tlr servive manual with twins throttle body but the F115LA has a single throttle body..
                people that do not have that motor have no reason to have a service manual for one.
                a shop near you might if they work on all sorts of these motors
                  Why do you not have the correct service manual?
                    imagehosting
                      i have the 2006 manual for my own F115TLR,i am helping a friend who messed with his F115LA...he tampered with his tps when he could not get the engine started.He managed to get it to start but idle erratic...
                        upon inspection,his engine oil is overfilled....water intrusion in engine oil...spark plugs with signs of oil & rust..could not get ydis to do static test error engine running or in gear..
                          does the f115la isc rattle like f115tlr when key off?
                            thanks boscoe99...appreciate it..
