S150TXRU fuel pump leak
  • S150TXRU fuel pump leak
    Hi guys, I have noticed that the the lower fuel pump assembly is leaking gas when the engine is off through the little hole on front of it. its not a lot but its noticeable, what do you guys recommend? replacement or should I open it up ?
    thanks for inputs!!
    I would replace them all if you have not done that lately
