help with a 90 horse 3 cylinder 2 stroke 97
  • help with a 90 horse 3 cylinder 2 stroke 97
    Hello ive been trying to get this engine going
    replaced
    coil packs
    plugs
    cdi
    cleaned carbs
    fuel filter
    the second cylinder doesn't fire and when the engine is under load it doesn't have much power and burns gas it seems to be something electrical
    any help would be a appreciated
    thank you
    have you checked the CPS input to the CDI?
    that's what what makes cyl 2 spark.
      The cps was cleaned and it was getting some power on the tester
      But I should probably just switch it out completely?!!
        If it does not meet the spec in manual and/or you have not tested it properly I would do that 1st.
        I have no idea what getting some power means
