Any help would be appreciated. My 2001 runs great but alarms all icons and goes limp. Then it goes away and is fine then does it again. Feels like it’s a computing issue. Any advice would be greatly appreciated.
2001 150 2-stk runs good then alarms limp
Overheat alarm, although they don’t normally go away without having to increase idle in neutral to increase the water pump output.
What is the pee stream like, and when was the water pump changed?
Or I could be completely wrong, your oil sensors/ wiring might be faulty, presuming you have BOTH oil bottles full.Last edited by zenoahphobic; 05-08-2023, 08:29 PM.
Not too sure what "computer" you're referring to, but.....there is a couple of things at play here, temperature and oil, you will need to narrow it down to either one! When it alarms, can you remove the cover and feel the motor (carefully) to see if it's actually hot? Is there any indicator lights saying temp or oil coming on? Are both oil tanks full all the time? Maybe the oil pump can't keep up with the oil use? You are a bit vague in your description of the issue, so we need to know the very basics.Last edited by ausnoelm; 05-09-2023, 03:09 PM.
