'93 25HP 2 stroke
If the black/white power wire that inserts into the top of the coil pack (primary) has pulled out can it be securely reinstalled? I assume that opening the pack, if at all possible, isnt a good idea. There are tightly wound coils so my guess is they would unwind. This loose connection that has since pulled out completely must be the reason why the engine has been miss firing. Ignition coils aren't cheap though. New one is $140. Can a used one be reconditioned? Also, I saw a few used coils on ebay. These were listed as "tested", though no listing of resistance measurements. Too big of a risk to buy a used one at half the cost?
