Hey guys. Here we go again. Ive got a sputter--miss fire in neutral and in gear. Not to be confused with "bogging" down. When the throttle is anywhere from 1/2 to WOT and in neutral (high RPMs) I'm getting a sputter. Here is the breakdown:
**Of the 2 carbs, the top is brand new. Bottom is the older one, though it has been cleaned and had a new kit installed.
**Fuel is fresh
**No fuel leak between tank and carb
**New fuel pump innards
**New plugs
**Fuel is getting to the cylinders (plug are a bit wet with a dark brown oily)
**Plug gaps are correct
**Plugs are firing with blue and orange spark
*Both cylinders are within spec for compression
Met a small engine mechanic today while at O'Reily's auto part store. Had my engine/boat with me. We put the engine on flush and he adjusted the mix idle screw on both carbs. While on flush, engine sounded a lot better after his adjustment. Then I dropped boat in water and went for a spin. Still had the sputtering issue. He did say something about the magneto control lever located under flywheel.This is the lever that moves back and forth after DTC. After going for a spin in boat I let him know I was having the same sputtering issue. He thought it could be this magento lever.
Suggestions?
**Fuel is fresh
**New plugs
Suggestions?
