It looks like part # 1 has two (2) outside ridges. As in upper and lwr.. Never seen that before.. I wonder if someone may have changed the gear case at some point. If you want to send it to me,, I can more done for you with the pump then a pic. Salmon season got closed down for the first time ever.... Normal by now I'm booked 2/3 months out..not this yr
gonna be a fresh water boat year since we finally got some rain out here and the ramps are back in the water...
Does the water pipe going up fit it on the ID side ?? They are a bitch to install.. I work on mostly bigger motors. But they are all the same.. I forget which manufacturer refers to it as dampener. Which I found strange..I need a George Jetson flying unit. I'd stop over and figure it out.. Go ahead and degrease and take more pics.. Do u have a caliper ??
