I have a 2019 Yamaha 115 OB. I was charging the batteries and then had to use jump box to try and start the boat. The battery wasn't holding a charge so I bought a replacement, The new battery has 12.6 amps so it is charged. The radio lights ect work but there is no power to the trim/tilt or the starter. I looked at the fuse box and the 50 amp main fuse was blown. I replaced it and checked the other 20 and 30 fuses which seemed all good. Still no power to the engine or the trim/tilt. What could this be? Starter solenoid, ECM or is there some other fuse or relay not located in the fuse box located on the engine. Thanks
No Power to 2019 Yamaha 115 Outboard Engine or Tilt/Trim
Originally posted by Oldsilverback View PostI have a 2019 Yamaha 115 OB. I was charging the batteries and then had to use jump box to try and start the boat. The battery wasn't holding a charge so I bought a replacement, The new battery has 12.6 volts so it is charged. The radio lights ect work but there is no power to the trim/tilt or the starter. I looked at the fuse box and the 50 amp main fuse was blown. I replaced it and checked the other 20 and 30 fuses which seemed all good. Still no power to the engine or the trim/tilt. What could this be? Starter solenoid, ECM or is there some other fuse or relay not located in the fuse box located on the engine. Thanks
Look for a missed wire that you didn't hook back up after replacing the battery. Not saying that's the issue - but it's a good place to start.
