Anyone have any input, I enclosed pics. Is it 1 or 2 with the M, both seem to have pistons and the top of the stroke. Tried putting a dowl inside both cylinders but due to the piston being offset from the spark plug I can’t get an accurate. Any help would be appreciated.
Top dead center
Originally posted by boscoe99 View PostHave you any idea as to the model and brand of the motor?
now I just need to figure out why she’s running hot. Did everything. Thermo, water pump spark plugs carb rebuild. Spark plugs showing hot lean condition. I’m lost. Thought I had a clog around the cylinder heads etc. so pulled the head. I don’t see anything obvious or anywhere near clogged.
